2007 Infiniti G35 coupe problems
cneihaus
Car: 2007 Infiniti g35 coupe
The car will start, loaps a couple times and dies. The car starts every time, no engine diagnostic codes, no engine noise, doesn't run hot. Any suggestions to what it could be.
joe603
Car: 2014 Durango R/T
Have a dealer put a sensor on it to see what codes it's giving. sounds like engine management (spark timing) to me.
cneihaus
We hooked it up to the diagnostic, there were no codes given
joe603
Well is the fuel pump getting fuel to the engine? (you do have gas I assume...) Have them put a gauge to measure pressure on the line. Next would be ignition modules need to be tested.
Have you taken it to a dealer?
cneihaus
I haven't taken it to the dealer yet. When I turn the key I hear the fuel pump turn on. :) If its pumping I don't know. I'll check the fuel line pressure. Then the fuel pump assemble.
cneihaus
The car has been fixed. A friend is a mechanic with Infiniti dealership he looked at it had it running in a few minutes.
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
Well share the fix
cneihaus
I will get more info about how it was fixed tomorrow. As I wasn't here when it was repaired
cneihaus
OK the Battery was unhooked reset the ecm and everything worked great. Not sure what the problem was but that fix whatever it was.
joe603
post up if the problems crops up later...
