2007 G35x without Navigation
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
slogan1100
Car: 2007 G35X
I just purchased a 2007 G35x without Navigation. What options do I have to retrofit Navigation and possibly a back-up camera? I have seen options posted for other models and years. I would like to know what I can do with my 2007 G35x specifically. Thanks.
pippen99
Car: 2010 Infiniti FX35 AWD
You have three options for navigation: Trade for a car with navigation, aftermarket unit such as a Kenwood, or Garmin. The wiring harness non-nav vs nav is completely different making a retro-fit nearly impossible. I'm not sure about the backup camera but just guess the answer is the same.
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
pippen99 wrote:You have three options for navigation: Trade for a car with navigation, aftermarket unit such as a Kenwood, or Garmin. The wiring harness non-nav vs nav is completely different making a retro-fit nearly impossible. I'm not sure about the backup camera but just guess the answer is the same.
they do make aftermarket back-up camera. most are installed above the license plate frame. as far as nav, i recommend a stand-alone garmin.
others have installed a blackbox nav unit utilizing the existing monitor. you would have to get a touch-sensitive screen to put over the existing monitor. it is possible, but probably not worth the headache.
audtatious
I agree with both of the above responses. If the requirement is to have Infiniti factory NAV then don't get the non-Nav car because there is no real path to installing all the parts and components needed.
Return to “G35 and G37 Interior, Exterior and Audio”
