2007 G35x Navigation upgrade question
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
MartinK
Car: 2007 Infiniti G35x
Hi, I I have 2007 G35x without navigation and found 2007 G35x with navigation for parts, what parts from this car do I need to have navigation in my car?
Thanks for any advise
audtatious
The best answer is to purchase one that has navigation and not deal with a swap. I looked into doing the same thing for mine but I don't think anyone had successfully done the swap. If you have all the parts that can be pulled from another vehicle and swapped over you can sure give it a try. Will probably need some wiring harness parts, the CD/NAV unit, touch screen, front panels, trunk-mounted CD changer, etc.
MartinK
I couldn't find one for sale with sat nav that time, he can give everything what I need to make it work, was wandering one think where is GPS receiver? is it build in in CD/NAV unit?
audtatious
I can't look it up for you at this time but you can go through the FSM and find about everything you need:
http://www.nicoclub.com/FSM/G35
MartinK
audtatious wrote:I can't look it up for you at this time but you can go through the FSM and find about everything you need:
Thank you very much for that
audtatious
If you successfully do a swap make sure you post here exactly what you did. Others would highly appreciate it.
MartinK
I will
Eagles34
Car: 2008 G35 Sedan
Have you been able to get the stereo swap done?
Looking to do the same with my '08 G35, and was told by the dealership that it was not a possibility.
Would like to know what parts you had to get in order to make this one happen if you were successful.
Thanks.
Return to “G35 and G37 Interior, Exterior and Audio”
