The car fired up and when I put it in gear, the engine killed and never started again. The car has been sitting now for about 6 months, now I have time to look into the problem. I now notice a flashing red car symbol with key in it on cluster blinking. Key fob is inserted into the key slot on lower left of dash. Battery needs replacing in fob.
Any direction on what needs to be checked.
All cam position sensors continuity are in the 450 range, cam position sensor was similar, forgot exactly. Even though the numbers are in range from what I've read, (200-1000) is it possible that any one of the sensors could be bad? Fuel pressure 52psi. I didn't pull injectors or know how to test fuel rail. Fuel test was done at the fuel pressure regulator on bank A side.
Any help is greatly appreciated. I am an old V-8 carburetor kinda guy, this is all new to me.
Thanks
