2007 G35 Suspension Kit
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
jkroig
Car: 2007 g35s
I just picked up a 2007 G35 S and was wondering if anyone has any suggested lowering suspension kit for the 2007 G35.
G_whizz
Car: 2010 G37 Coupe Sport
Coupe or Sedan?
Congrats on the new ride!!
jkroig
Car: 2007 g35s
2007 G35 S sedan
dbaquiran
Car: 07 g35 sports sedan with 20 inch staggered neeper moxy with 245/35/20 front & 275/30/20 rear
i got h&r sport springs and they ride way better than the stiff stock springs which is not even lowered...1.3 in the front and 1.2 on the back and it looks like its really low...
dbaquiran
G_whizz
Looks HAWT!!
jkroig
Car: 2007 g35s
Looks Great. What size wheels are those?
kmech_7
Car: 2003 Infiniti G35 coupe (Skyline) Vortech Supercharged Jul 08 ROTM
looks like 20's to me
BigWill
Car: Gone, but not forgotten-2004 G35 Coupe-5AT-Graphite Now-2008 Black Saphire IS 250
Bro... that is one of the cleeeenest sedans I have seen yet!
slo poke
Car: 2007 Infinity G35 Sedan S 6mt
Do you have any camber issues with those springs? I was looking at them but I want to make sure that they don't drop too much so I have enough adjustment to set the camber back to spec.
shimman
dbaquiran wrote:i got h&r sport springs and they ride way better than the stiff stock springs which is not even lowered...1.3 in the front and 1.2 on the back and it looks like its really low...
great looking car
i was thinking about lowering car, too, but i am bit concerned because kits i looked at lowered front more than rear. wouldn't it upset the balance of car's weight distribution?
another concern is the suspension setup; since the car is lowered, the geometry of suspension on normal position has been changed, and i am wondering whether there should be any adjustment for the change especially complicated rear multilink setup?
can you elaborate "ride better"?
btw, do you have any clearance problems? did it improve handling?
thank you
terrycs
slo poke wrote:Do you have any camber issues with those springs? I was looking at them but I want to make sure that they don't drop too much so I have enough adjustment to set the camber back to spec.
I've been doing quite a bit of research on this.
The current H&R kit will have minor camber issues on the front. Rumor has it that H&R is in the process of redesigning the springs instead of using the 2006 kit on the 2007, so I'm not sure what will happen.
Eibach has just released their pro-kit for the 2007 and is in production now. Parts should be available shortly. The production Eibach kit drops the car 36mm in front and 33mm in back. Camber will be out of spec slightly on front and back.
terrycs
[QUOTE=dbaquiran]
Do you have any rubbing on the back when the car is fully loaded with passengers?
dbaquiran
no rubbing at all..even my fat *** dad was riding at the back with my bro and didn't even rub at all....it goes in the fender wall...
soul_hfk
Car: 2010 G37xS---08 QX56
WOW love the wheels
The Punisher
Car: Mustang GT
That car and rims are bad ***! You pulled it off quite well. What model wheels are those? That's if you don't mind sharing.
Edit: saw your sig. what's the offset on the rear?
Modified by The Punisher at 12:01 AM 3/9/2007
dbaquiran
20x10 rear 40mm offset
BOOMSHAKALAKA
Now that is a hawt G sedan right thar!
paulp
Car: 98 s14 se, 07 g35 sedan 6mt
i gotta say that sedan is gorgeousive been debating weather or not to do 20s on an 07 sedan as well
what profile are you running on thatwhat size and offset are the frontcan i get away with not lowering the car with 20's, and if so, will it look too talllastly, how different is your ride quality whit big rims and lowered suspension versus stock
thanks in advance for your help
vpnetwork
Car: 2008 G35 Sport Sedan
Dude! love the setup. Can i take her on a DATE?
Can you tell me the Offsets?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
