2007 G35 Spec's
Bugaboo
Car: J30
At a Glance: 2007 Infiniti G35 Sedan
Inside, the all-new interior design is refined, inviting and offers a new level of modern warmth and hospitality. The G interior also offers unique features such as the white-and-violet Fine Vision gauge illumination and high-touch, textured aluminum-alloy trim with "Washi" (traditional Japanese handmade paper) patterning.
Available advanced technologies include RearView Monitor, a touch screen navigation system with available real-time traffic and the audiophile-quality Infiniti Studio on Wheels(tm) by Bose®, combining the industry's first 3-way front door speaker array using 10-inch woofers with an audiophile quality head unit incorporating a 24-bit Burr Brown® Digital Audio Converter.
The heart of the G35 remains its advanced engine, platform and drivetrain, anchored by the "next generation" of the award-winning VQ-series 3.5-liter DOHC V6, now rated at an estimated 300-plus horsepower*. The standard V6 is mated to a choice of a 5-speed automatic transmission with manual shift mode and Downshift Rev Matching or close-ratio 6-speed manual transmission. Steering wheel-mounted solid magnesium paddle shifters are standard on the G35 Sport A/T model.
The G's second generation FM (Front Mid-ship) platform features a 4-wheel independent suspension with lightweight aluminum components and improved body stiffness. The 2007 G35 is also offered with Infiniti "intelligent" all-wheel drive system.
Highlights of the 2007 Infiniti G35 Sedan include:
Body
Advanced Front Mid-ship (FM) platform (second generation) An evolution of the original G35 design with a long, wave-like hood, pushed-back A-pillars and aggressive stance Enhanced sense of dynamic surface tension and polished craftsmanship Double-arch grille with sculpted grille blades, High Intensity Discharge (HID) bi-xenon headlights, integrated fog lights, L-shaped LED taillights Unique front fascia and side sills on Sport models Available Adaptive Front lighting System (AFS) Available rear spoiler on Sport models Lightweight aluminum hood, available heated outside mirrors Available sliding glass sunroof with tilt and one-touch open/close feature Eight available exterior colors, including four new colors Engine and Driveline
New fourth generation VQ-series 24-valve 3.5-liter DOHC V6 producing an estimated 300-plus horsepower New ram air dual intake, equal length exhaust manifold and dual exhaust system with laser-welded rear mufflers Higher compression ratio (10.6: 1 versus previous 10.3:1), higher redline (7,500 rpm versus previous 6,600 rpm), new eCVTCS (electromagnetic variable exhaust cam timing), twin knock sensors, improved cooling and stiffer engine block structure Refined electronically controlled 5-speed automatic transmission with Downshift Rev Matching and DS mode and ASC (Adaptive Shift Control), or close-ratio 6-speed manual transmission Rear-wheel drive Magnesium paddle shifters on Sport A/T model Standard rear viscous limited-slip differential with Sport models (5AT and 6MT) Front engine/rear-wheel drive or ATTESA E-TS(tm) all-wheel drive (G35x AWD model) Suspension, Steering and Braking
Redesigned 4-wheel independent multi-link suspension with extensive use of lightweight aluminum components, front and rear stabilizer bars Available sport-tuned suspension (Sport models) New power-assisted vehicle-speed-sensitive rack-and-pinion steering 4-wheel power-assisted vented disc brakes, 4-wheel Anti-lock Braking System (ABS), Electronic Brake force Distribution (EBD) and Brake Assist (BA) 17-inch aluminum-alloy wheels with P225/55R17 V-rated tires Available 18-inch aluminum-alloy wheels with 225/50R18 front and 245/45R18 rear tires (standard on Sport models) Standard Vehicle Dynamic Control (VDC) Standard Tire Pressure Monitor System (TPMS) Interior Features
Driver-oriented interior styling with fine craftsmanship and modern warmth Standard leather-appointed seating, available in Beige (except Sport models), Black or Gray Unique "Washi"-pattern (traditional Japanese paper) aluminum-alloy trim on center console, instrument panel and doors Standard 8-way power adjustable driver's seat and 4-way power adjustable front passenger's seat Hand-stitched leather-wrapped steering wheel with steering wheel mounted audio and cruise control switches Fine Vision gauges with white and violet illumination Available wood trim on center console, instrument panel and doors Standard Infiniti Intelligent Key with Push Button Ignition Available Infiniti Studio on Wheels by Bose, combining the industry's first 3-way front door speaker array using 10-inch woofers with an audiophile quality head unit incorporating a 24-bit Burr Brown® Digital Audio Converter Standard audio system featuring in-dash CD changer with mp3 playback capability and 6 speakers Leather-appointed and aluminum shifter lever Available Infiniti Navigation System with available XM® NavTraffic(tm) real-time traffic information Available Bluetooth® Hands-Free Phone System Available RearView Monitor Available sport-styled front seats with thigh extensions and power torso and thigh bolsters Available sport-styled steering wheel and aluminum pedals Available satellite radio with choice of XM® or Sirius(tm) providers Infiniti signature analog clock Digital automatic temperature control with standard micro filtration and rear heater vents, available dual HVAC control with available rear vents Available Intelligent Cruise Control (ICC) Safety and Security
Standard Advanced Air Bag System with dual-stage front supplemental air bags with seat belt sensors and occupant classification sensor Standard front-seat and front and rear curtain side-impact supplemental air bags 3-point ALR/ELR seat belts (driver's seat ELR only) Front seat belt adjustable upper anchors with pretensioners and load limiters Front seat Active Head Restraints Zone Body construction with energy-dispersing side structure Engine mount breakaway design with breakaway driveshaft Retracting brake pedal to help reduce lower leg injuries in severe crash LATCH (Lower Anchors and Tether for CHildren) child seat anchorage system Models and Manufacturing
Available in five models: G35, G35 Journey, G35x AWD, G35 Sport and G35 Sport 6MT Assembled by Nissan Motor Co., Ltd. In Tochigi, Japan ###
BIGT94z
wow that's alot to read...whats the base price gonna be?
rydwhite
Car: 2003 Infiniti G35 Coupe
Thanks for the info.
It seems like Infiniti has listened to the people and made some nice improvements and additions.
The pics for the '07 look great and I really do love that interior. I big improvement as long as the materials are of good quality. No more cheap plastic hopefully.
