2007 G35 Sedan - Oil / Filter warning reset procedure
rbarnesky
Car: 2007 MT6 G35S Sedan
Can anyone share with me how to make the annoying orange center screen warning messages telling me to change the oil and filter go away? I changed my oil and filter and those two warning items will not disappear. This car has the NAV system. There is nothing in the manuals that tells how to reset the warning to make it stop coming on as soon as the car is started.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
on my 03 with nav. You press the info button which gives you options for fuel economy, maintenance etc. Press maintenance and it should get you to a screen that shows your oil and filter life. Should be an option to reset.
telcoman
rbarnesky wrote:Can anyone share with me how to make the annoying orange center screen warning messages telling me to change the oil and filter go away? I changed my oil and filter and those two warning items will not disappear. This car has the NAV system. There is nothing in the manuals that tells how to reset the warning to make it stop coming on as soon as the car is started.
Since you have an 07, I would recommend you ask the service department at the dealer?
How many miles are on the car/& since last oil change?
Telcoman
rbarnesky
The car has just over 4,000 miles. The oil and filter were changed at 3,750 miles as per the manual.
telcoman
rbarnesky wrote:The car has just over 4,000 miles. The oil and filter were changed at 3,750 miles as per the manual.
I have an 06 sedan with 41k miles that will be two years old on New Years Eve. The only two problems I've had were one defective tire pressure sensor and a defective drivers air bag sensor both replaced under warranty. Perhaps you have a defective sensor which the dealer will replace at no charge. You can make an appointment on the internet & request a loaner. My dealer will even come to the house to pick up the vehicle & leave the loaner.
Telcoman
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
Did you try my suggestion?
soul_hfk
Car: 2010 G37xS---08 QX56
look to the upper right by the wheel or to the left of the NAV system
infinititech1
talkin about the one between the gauges?
