cnhodge »
https://forums.nicoclub.com/cnhodge-u206769.html
Thu Jul 12, 2012 8:26 pm
So I just got my wife a 2008 G35 Sedan Sport yesterday with the Navigation. I tried the following hack several times, but no luck. Can anyone tell me if they have gotten this to work?
alright heres the hack a guy at the stereo shop told me.
make sure the car is off first.
then the ignition to "ON".
Once the navi turns on, click ok, then goto "INFO".
Once in the info screen, with the joystick hit" Up, Up, Down, Down, Left, Right, Left, Right and Then push the joystick to confirm.
Then, turn the car one, make sure ur on neutral.
Rev the car to 3k stedily, at the same time, go back to the naviscreen, and you should see "set navi override on/off. Theres also a setting that will disable the navi once the car reaches certain speed. the Dealer sets this at 5mph... You can change it to zero... or just set the safety feature to "OFF"..
Click "OFF". A warning screen will pop up... Click "OK".
Now it will ask you if you want this feature to be off for just the ride or infinit... Click "infinit".
