smockers83 wrote:Not necessarily bad news, you can convert those into MP3s. Try copy and paste between the folders. If that's not working, then the only thing I can really think of is that there may be a small tab on your drive that protects it from being written to that can be moved (on/off-->write/can't write). If that doesn't work, I don't know what to tell you, it shouldn't be difficult at all and that's what Apple is known for.
Where might I find that small tab on the "drive"?
Not sure what you mean by copy and paste between folders?
It's weird. I bring up I tunes and select the smart playlist with all my music. Then I go to Finder and select the card reader. I can see both on the screen. When I go click on the playlist to drag it over, the Finder window ends up behind the I tunes window. Arrgggggg........
John
