2007 G 35 brake job finished!
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
turbobrian wrote:Why did you chose cross drilled and slotted? They wear out your pads faster and cause more break dust!! Bad choice for a daily driver. They look cooler I guess if you were going for more of a look than what will work best.
guess you missed my signiture?
Modified by gwoods at 2:01 PM 3/24/2008
gwoods
phil4watching wrote:Nice man. looks awesome. how much did all of that run you if you dont mind me asking?
$339 plus a couple hours of my time
goneracin
Car: 2004 G35X Sedan 1990 Mustang conv.
Be sure to warm up your brakes before heavy use and cool them after. I've warped a front set of Baer brakes on my mustang in less than a year of autocrossing. They don't really allow for warm up laps. I've since then switched to slotted only. Works great for my appl. and they are lasting much longer. What you have there probably does perform better on the open track. Just do a warm up and cool down lap and they should last you a little while.They look great by the way!
I did not catch it; what pads are you running?
BigWill
Car: Gone, but not forgotten-2004 G35 Coupe-5AT-Graphite Now-2008 Black Saphire IS 250
Can cross drilled/slotted rotors be turned? No matter how diligent you are with changing pads, at some point the rotors will need to be resurfaced... or replaced if they can't be turned.
goneracin
Sure, you can get cross drilled / slotted rotors turned.
joe603
Car: 2014 Durango R/T
Yes, I've had cross drilled rotors turned before.
gwoods
Yeah I did a warm up lap and cool down lap everytime I went out on the track and I still killed my factory brakes.
The pads are kind of a bastard. The fronts are ceramic, I bought them from the company that made the rotors custom for me.
The rears are the red stuff ceramic/kelvar blend.
If I get a year out of the brakes I'll be happy. I drag race the car at least once a month and auto cross about 4 times a year.
With full slicks on all four corners the factory brakes just can't keep up.
Drilled/slotted can be turned if there is enough caliper material to turn. Hopefully I'll just wear out the pads and be able to just replace pads though without turning. I have a spare set of ceramic pads and my stock rotors sitting in the garage.
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
Nice Job Nico Mechanic!!!
gwoods
Thanks
danielekfuj
Car: miata, rocket ship
rn79870 wrote:
I think I like "Likes to pick daisys" better. It has a nice ring to it.
gwoods
danielekfuj wrote:
kevgoodwin
Car: 2003 Infiniti G35
Isn't it also a good idea to clean the new rotors really well to remove all oil or contaminants?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Yes...it is a good idea to clean rotors before you install them. use a good brake cleaner fluid and a clean rag.
audtatious
BUMP
Can we get the images rehosted? PuhLeeeze?
gwoods
:ohno: Hey Matt don't ban me!
I just emailed them to your Nico email address in nice little 12-15 mb packages.
The way my life is going who knows if I will have a photobucket account tomorrow or not. My original photobucket account was deleted April 1st last year.
2fast4bmw
Car: 2004 G 35 Coupe
Every car needs that "personal touch" it's what we do, stock is boring! I will be doing a cold air kit, found a nice one on ebay from Canada, looks very well designed. Then LED lights where the standard bulbs are, soon 18in Hyper Silver wheels with tires that have taken me a month to figure out which ones to get..lol. Next and very soon, new rotors and pads! My 99 Civic stopped better, the guy I got the car from did his own brakes,,,,,,,Then the transmission oil, I know S matic, only. Lucas oil stabilizer with some good oil, have to choose that, and lots more!
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
