2007 FX35 blower motor replacement
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
FatBoyJon
Car: 2007 Infiniti FX35
I have a 07 FX35 that the blower motor has gone bad on. It sounds like bad bearings. Lots of noise and rattling. The fan works on all setting and blows good heat. Do I get to the blower through the glove box? Is it quite a job to change? I've done them on a couple Ford trucks and all went well. Thanks for any help!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
According to ATC-122, it looks like you'll need to remove the glove box (which looks like just the cover under the glove box, according to IP-10), then it's just the wire harness and 3 screws.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
