2007 Frontier leaf springs
job114
Car: 2007 Nissan Frontier
I would like to know if anyone is having a problem with cracked leaf springs. 6 months ago a leaf broke on the driver's side, I had it replaced. Now the passenger's side cracked in the exact same spot. I do not carry heavy loads, it has only held skis and snowboards since November. I am over the mileage for warranty coverage. Any help would be appreciated.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
this issue has been around a long time. I broke leaves on 3 separate occasions on my D22 before I got aftermarket leaf packs.
Are you still under warranty?
JC87HB
Car: 1987 Nissan D21 HB
yah man.. id go after market pack!
EDIT** unless you are under warranty still....
RT22
Car: 1991 nissan hardbody
did they fix that problem in later models? if so get some out of junkyard on fixed models, if they fixed it that is.
job114
Thanks for the help, I will probably go with the after market springs. Nissan was of no help with this problem and wanted to charge me twice what the my guy would. Thanks
