diesel266 wrote:Ok, so I'm new to this site. My wife and I bought a 2007 Nissan Murano in 2008 used with 30,000 miles. We so far love this car and as of Feb. 15 it has 124,000 on it. My question is, we are planning a trip and I was planning on taking the car to get a oil change and get the transmission fluid changed (which I always tried to do in my other cars every 100,000 miles). I did some searches on line and saw that there have been a some issues with the transmissions in there cars. So it kind of scared me. I thought that the car was well made enough to make it to 200,000 miles, but now I'm very worried. I called the dealership to see if they could check out the transmission for any issues under the new warranty (nissan has extended the transmission warranty to 10 yrs, 120,000 miles) and I was told that we were 4,000 miles over the warranty (total bullsh*t) I asked about changing the fluid and the guy told me that since we haven't changed it yet, that its best that we don't even touch it. Just run it the way it is. This makes no sense to me. I thought changing the fluid would be good for it. He said that since we never did it according to the service plan (every 30,000 miles) that we missed our chance and its best to just let it go. Any info on this would be great. Also, are the CVT transmissions any good. Will they last or are they just junk??? So far the car runs great, but I so scared about the possibility of the transmission breaking. Since there are now gear on gear, is there less chance of the transmission going bad and the fluid isn't as important as it is in a normal transmission. Please help. Very much in need of some schooling on this stuff...
The dealer probably isn't bs'ing you. Believe me they will say whatever they can to get you to bring your car in for service.
As a Mod on another one of the forums said, parts wear and become smooth; if you change that "dirty" fluid now there may not be much for the gears to "grab" onto. Basically that dirty fluid is keeping it going.
There are many stories of people getting high mileage transmissions flushed and it kills the transmission. Your dealer is protecting themselves from that happening if they flush it.
You could just try a drain and refill as that will take out about half the fluid. Make sure you use only Nissan CVT fluid. You could do this yourself, just google it and you will find videos/ guides.
CVT's are not like old transmissions, they need to be taken care of very well.
Also, you are 4K over the extended warranty so even if you were under 120K, they would not of looked at it for free or changed the fluid for free. If there was a problem with the CVT and they looked at it and found an issue then they would replace it for free.
