2007 coupe cold air intake?
nismodan69
Car: 2007 g35 coupe 5AT sport
hi guys happy new year! well ive been trying to look around for a cold air intake for my 2007 g35 coupe but all the ones i look at online are 2003-2006. would the aem CAI for 2003-2006 fit on the 2007 coupe? there is no difference in the engines.. i dont know why it doesnt include 2007..
joe603
Car: 2014 Durango R/T
Welcome to NICO!
The 05-07 coupes are exactly the same. The 03-04 models are non-REVUP versions of the VQ engine. Might I suggest the Stillen PopCharger with a Z-tube. Check out these guys for good prices.
http://www.g35parts.com/9083/o...58_21
nismodan69
thanks alot man.. just a few questions. what do you mean by the 03-04 are non-rev up versions of the vq? and when i went to that page there is no stillen popcharger only a jwt popcharger with z tube. there is a popcharger but not made by stillen.. was that one the one you were trying to recommend? are their any intakes that might be better? money is not too much of a factor
joe603
The 03-04 engines are an older design of the VQ35. The 05-07 versions have what's called a REVUP. It increased the max RPMs by using different components and a redesigned intake setup. They also added variable exhaust valve timing (they both have variable intake valve timing). Do a search to find out more.
As far as what to get...I'll make it easy for ya!
Get this: http://www.g35parts.com/9083/o...d=396
This: http://www.g35parts.com/9083/o...d=317
This: http://www.g35parts.com/9083/o...d=364
This: http://www.g35parts.com/9083/o...d=215
And this: http://www.g35parts.com/9083/o...d=119
grantman240z
Car: '03 G35 Coupe 6MT
joe603 wrote:The 03-04 engines are an older design of the VQ35. The 05-07 versions have what's called a REVUP. It increased the max RPMs by using different components and a redesigned intake setup. They also added variable exhaust valve timing (they both have variable intake valve timing). Do a search to find out more.
And this: http://www.g35parts.com/9083/o...d=133
nismodan69
haha thanks man i guess this is the outline for my performance modifications! lol just a few questions.. what exactly does the plenum spacer do? and which of those upgrades will possibly void my warranty? and what can i do to avoid voiding warranty if i install those parts? also would you suggest also getting a throttle body spacer? oo and a big question.. i was reading the mrev2 info and it said about some of the vqs running lean with the spacer.. does my 5at have that problem?
joe603
The plenum spacer increases the volume inside the upper intake plenum for more usable power in the RPM range. For G35's with the REVUP (05-07), the MREV2 will give the most gains with use of the spacer. Check out this site for info: http://www.motordyneengineering.com/faq.htm
Here's the thing on warranty's...
Any modifications you do to your car that have a direct affect on the system that failed, will void the warranty.
To put it another way, if you put on an intake and your throttle body fails, then you might not get warranty work done for that item (out of pocket). However, if you put on an intake system, and your seats no longer recline, because your mod has nothing to do with the problem, it will be covered under the factory warranty. The main one that bites people is suspension mods.
nismodan69
well ive been reading around and ive been looking at headers.. are there any aftermarket performance headers for the coupe that are street legal in miami, florida? and do headers make a big performance difference for the gs? more specifically an automatic one? thanks in advance
joe603
I don't recommend putting headers on the car. The gains are very minimal, and the cost on the install is high. If you want better exhaust breathing, get a CAT-back exhaust system. For even more power, off-road pipes that replace the cats will give you a good boost (for track days).
haloseven
Car: '07 G35 Coupe, 5AT, Black on Graphite, everything but nav
In PA, Infiniti has to PROVE that your mods caused damage.....you might even be able to get that throttle body covered. Not that I've been there.
nismodan69 wrote:haha thanks man i guess this is the outline for my performance modifications! lol just a few questions.. what exactly does the plenum spacer do? and which of those upgrades will possibly void my warranty? and what can i do to avoid voiding warranty if i install those parts? also would you suggest also getting a throttle body spacer? oo and a big question.. i was reading the mrev2 info and it said about some of the vqs running lean with the spacer.. does my 5at have that problem?
