2007 Altima: Is it CVT or not?
General discussion area for the L32-chassis Altima
Harbison
Car: 2007 Altima
Looking at a 2007 Altima 2.5 S. How do tell if it's CVT or not? If it is CVT, what should I check for? Seemed to drive and shift fine.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
That's easy. If you have to shift gears to drive, it's a manual transmission, otherwise it's a CVT. The ONLY automatic transmission offered for your model year was a CVT. BTW, if you open your hood there should be a warning label advising to use only Constant Variable Transmission fluid to avoid damaging the transmission.
Harbison
Car: 2007 Altima
Thanks for the reply. I couldn't find anywhere if CVT was the only automatic transmission offered in 07 on the Altima.
Return to “4th Generation Altima Sedan (2007-2012)”
