2007 350z won't start! Plz help!!
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
lht102
Symptoms:
1. Sometimes it'll start but then will sputter and die within 1 or 2 seconds.
2. Sometimes it'll just crank and crank and crank but won't start. Been sitting in garage for a week now...
Before the problem:
1. I forgot I left the headlights on so battery died.
2. Jumpstart but won't work, even tried to crank and pump gas pedal at the same time. I heard this will flood the engine?
What I've done:
1. Replaced new battery. Tightened up all the wires.
2. Check fuses
3. I can hear fuel pump working when I put key on ON position.
4. I know it's not the key fob or safety anti theft issue, bcus red light off when I put key on ON position
5. Depressed gas pedal then try to turn it on.
I don't think the alternator or starter are bad right? Bcus if it is then car wouldnt sometimes start then shut off immediately and sometimes just crank only.
frapjap
'07 Subaru Legacy
Have you checked for spark? Pull off a plug wire, lay it near the valve cover, and have someone crank the engine. See if you can view the spark arcing.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Thanks Ray, you beat me to what I had in mind. It would be great (not to mention an easy fix) if it's just a faulty/fouled plug.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Has nothing to do with your starter or alternator. Step one is pull the codes, if you don't have an OBD2 code scanner, borrow one, many parts store will loan them with a deposit. My first suspect would be the NATS antenna which seems to eba common issue but if thats the problem it won't throw a code and you'll have to go to the dealer. Could be Crank angle sensor, it can fail intermittently.
lht102
So I checked fuel, sparks, fuses etc... everything good. Cleaned out the throttle body and now car will start and idle, but if I press on gas rpm won't change and if I put in gear the car will shut off. Any inputs?
evildky
06 Nissan 350Z GT
Have you checked for codes? Could be the pedal, could be the TPS. The fact taht you just cleaned the TPS makes me suspect the tps, check the plug make sure it's getting good contact and no moisture is in the plug.
lht102
Codes:
P2101
P2119
P0605
P1225
lht102
Codes:
P2101
P2119
P0605
P1225
evildky
06 Nissan 350Z GT
So three different codes that all point to the TPS, I'm gonna go out on a limb and say your TPS is bad, lets hope replacing the TPS clears up the ecu code
lht102
Trying to unplug the batter for the night see if it'll do any help... also will relearn the tps do any help?
evildky
06 Nissan 350Z GT
If you haven't already it's worth a shot and cost is zero$. I haven't checked the price on the TPS not even sure if it's sold separately or if you have to buy a complete TB. You should definitely clean and check the connectors before throwing parts on.
Aztec
Car: 2003 350 Z touring model
I dont know about his 2007 but on my 2003 the TPS is not serviceable had 2 replace the TB, 1 of the local auto parts store sells a brand new 1 for 278.00 Nissan wants 768.00
Return to “350z / 370z Technical”
