nervman »
https://forums.nicoclub.com/nervman-u95292.html
Tue Apr 22, 2008 5:55 pm
Hello everyone, I recently bought an 07 350Z that runs quite well except for one problem. (lol, I'm sure if a nickel fell out of the sky each time someone said that on here..)
Anyhow, when starting my car up from a cold engine and driving a couple minutes to where it has just warmed up I get hesitation issues below 2500 RPM in any gear, and is also reproducible in neutral (6 speed manual). This hesitation only occurs on very light acceleration and once the car warms up fully it dampens out a lot to where its not noticeable. The most interesting way for me to reproduce it is to sit in neutral and slowly let the RPM climb and every time right on the money the needle will sort of stick and engine bog a bit precisely at 1750 RPM, every time before finally moving up again. )As time goes on from being fully warm the amount of bogging gets smaller and more dampened)
I'm certainly not a car tech, but I have read that most vehicles starting up from a cold engine will not take inputs from most of the sensors until the engine temp gets to a particular point when they will be factored in by the ECU. My car operates perfectly fine until it reaches this now fully warmed up spot where the hesitation/bucking will occur and will soon dampen out. So I am leaning towards this being a sensor issue. I ordered 1 MAF to use in testing. This car has 2 MAF sensors (2 intakes) so I'll test on either intake with the assumption that the odds of both MAF being bad are probably kinda slim.
I would really appreciate it in being sort of nudged in the right direction as I continue to test and analyze the problem. What I really would like to do is remove both MAF sensors and run the car without either for about 10-15 minutes to see if the problem does not occur. I would assume that'd be a near sure fire way to eliminate the MAF, but is this a safe move to make and would I need to put some duct tape/masking tape over the holes when the MAF sensors are removed? I also replaced the air filters with new ones although I knew it was very unlikely to help anything.
So here is what I have planned:
- Remove both MAF, sensors run the car without it.
- Remove spark plugs and carefully retorque them or new replacements with a good torque wrench
- Replace O2 sensors (can this even be an issue) ?
- Check vacuum hoses (They seem fine to me though)
Anything else I should do, or anything I said I'd do that I probably shouldn't bother doing?
I REALLY appreciate any help I can get, its been irking me for a couple weeks. Although its not a severe issue, I don't really like taking off like a bucking bronco for that short space of time where the engine is just warmed up.
