2006G35X-- Steering Wheel Audio & Cruise button issues
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
St.Louis- Cardinals
Car: 2006 G35X
The Audio and Cruise control buttons on my steering wheel have stopped working unless the wheel is turned at least 90 degrees. Unfortunately, this makes them useless in normal use. Does anyone know if there is some sort of "contact switch" in the steering wheel that may have gone bad? Thanks!
St.Louis- Cardinals
Car: 2006 G35X
A little research seems to indicate that the steering wheel needs to be removed and that the Clock Spring has gone bad and needs to be replaced.
A very helpful YouTube video: https://www.youtube.com/watch?v=EPQ2sEYjKJU
audtatious
yeah, seems to be the issue. Pretty good how-to video you found!
FSM for working on the vehicle is here if needed: http://infinitiservicemanual.com
St.Louis- Cardinals
Car: 2006 G35X
Thanks Audtatious for the FSM link!
The best price I can find is about $150 brand new OEM on eBay.
audtatious
Probably cheaper than directly from the dealer and if you are doing it yourself you can avoid the labor costs.
Return to “G35 and G37 Interior, Exterior and Audio”
