Niti QX4 »
https://forums.nicoclub.com/niti-qx4-u273552.html
Sat Nov 25, 2023 7:09 am
CL is the centerline. Make sure all dimensions are to factory specs. CL distance from cams CL to crank CL Check all CLs. Cam to cam, cam to crank, etc. Verify all dimensions meet nominal specs.
Odds are slim, but if the block was decked previously, and if the heads have been milled too much and the head gasket is too thin, you may be at the tolerance limit of the chain tensioner system.
Only way to confirm is to measure CL distances.
Also, any chance it be the CVTC causing the noise?
