nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Tue Jun 16, 2009 11:08 am
So you took the stock exhaust mani off and put a header on. Is the main cat still in (basically underneath the front seat area in the exhaust stream)?
If yes, just have the wiring on the 2nd O2 sensor extended so that it can go behind the main cat. You'll have to have a bung welded into the exhaust back there too.
The cat in the stock exhaust mani is just a precat for when the engine is cold. The one underneath the car does the bulk of the work.
Alternatively, you can get a spark plug defouler and do that trick. Check the Table of Contents linked in my sig, the Common Fixes thread has an explanation.
Getting rid of a 2nd O2 sensor code is easy.
