I changed transmission fluid today. I followed the directions from one of the YouTube videos. I also checked FSM to be sure, I am dealing with right plug.
A couple of questions,
- Does Transmission drain plug work in opposite direction that of the oil drain plug? The rule is, lefty loosy, righty tighty. The drain plug of my transmission was exactly opposite. Quite confused me.
- Following is how the drain plug looked like. It doesn't look like OEM because the size required was different than what is suggested on the board. I used 19mm socket.
Can anyone confirm this is a non-OEM drain plug for transmission and size of the OEM drain plug?
Many thanks in advance.
