2006 sedan alignment questions
lawson3
Car: 2006 Infiniti G35 sedan
just aligned my g35 set rear camber and toe,noticed that right front camber was slightly out.is anyone aware of a good front camber kit fot the sedans.I am a honda tech and usually dont worry about slight camber issues,but just trying to improve tire wear.
infinititech1
yeah it sucks they come with negative camber from the factory...not sure about a camber kit tho
Q45tech
The bulk of the available street tires are designed to function properly with negative 0.5-0.7 degrees of camber. If one reads the midpoint [precise align] scale you will see that this is the number.
Unfortunately manufacturing sloppiness dictates a wider range to reduce warranty expense.
