The lock on the left-rear door on my 2006 Pathfinder stopped working and the door is locked shut. I was able to remove the inner panel and parts to access the power door lock unit, cables, etc. (no small feat with the door locked shut). I did get the door open once by pulling the cable and latch at the same time. I made the mistake of thinking if I did that once, I could do it again -- no dice. I now have the door shut and locked with no way to open it again.
Here is a video I took showing the sad state of affairs:
https://vimeo.com/382224714
It seems like my only option is to rip the lock mechanism apart from the inside (no fun at all). That would involve cutters, a hammer and whatever else I can squeeze into that small space until I can figure out a way to unlock it. Here's the part I need:
https://www.nissanpartsdeal.com/parts/n ... AUTO;6=LE)
Any thoughts on alternatives to doing a destruction mission?
