2006 qx56 shift cable
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
baldman62
Car: 2013 Infiniti QX56
Anyome have trouble with the shift cable breaking? I think mine has broken. Easy repair??? Shifter moves very easily. Dash displays the trans is in neutral. Cable is intact at the shifter. Possibly broken or disconected at the trans. Any advice would be helpful......
marctronixx
not a common thing, so dont be upset if not many reply.
i suggest getting the service manual for the car. you can find it on this site or google "x dot infinitihelp dot com" and grab it there.
baldman62
I found the problem today. The nut that secures the shift cable to the trans had worked it's way loose and came off. Luckily it was a quick fix, and i'm back on the road...
Return to “Armada Forum / QX56 Forum / QX80 Forum”
