WaynesNside »
https://forums.nicoclub.com/waynesnside-u139240.html
Sun Mar 14, 2010 3:24 pm
I know a lot have done this but I have been searching and it was not that easy to find the info so I wanted to post up for any new person wanting to do this to their QX
This will work on the 2007 but the wire might be a different color but I think it's in the same location on the connector.
Radio shack switch (275-0693)
Move the pass seat all the way forward, go to the rear pass door and remove the cover plastic (2 screws) piece that goes over the navi unit.
Look at the connector on the right on the back of the Navi unit. You want the wire (2006) white with red stripe. 4th wire in from the right side on the top. (picture) Splice your swtich into that wire. I installed mine on the front of the passenger seat bottom close to the center console on the plastic under the seat bottom.
It's pretty easy and took about 30 mins to do.
