2006 QX56 driver's side armrest removal - how to?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Boilermaker4ever
Car: 2006 QX56
I tried searching on this but found nothing.
The driver's side armrest of my 2006 QX56 is loose in the side-to-side direction. This is the armrest on the right side that is attached to the seat. The rotational motion up and down seems OK, it is just a bit sloppy (i.e. there is some lateral play) if i move it left and right. The passenger side armrest is fine.
Thinking there might be a bolt or nut that can be tightened beneath it, I tried removing the circular plastic button cap that is fitted to the outside face of the armrest (the side facing the passenger seat) located at the pivot axis. I assume this cap is a cosmetic cover that hides an armrest fastener beneath it. I pried a bit and tried turning it but the cap didn't want to move and I was afraid of breaking it.
Does anyone know how I can eliminate this lateral play in the armrest? Do I need to access a fastener below the plastic cover, and if so how do I remove this cover without breaking it?
Any and all help is greatly appreciated!
Modified by Boilermaker4ever at 6:43 AM 3/11/2010
Return to “Armada Forum / QX56 Forum / QX80 Forum”
