Hello and welcome to the forum.
Hopefully, someone with direct experience will give you the direct answer you seek, but this is how I would look at it.
From the EC section of the FSM, page 465 I see that you should look for intake leaks and probably change the PCV valves.
Apart from visual checks of cracks in the rubber, you can spray things like carb cleaner around the engine to try and pinpoint where there is one.
For the PCV, I'd just replace the valves.
This is what I'm talking about:
http://www.nicoclub.com/service-manual? ... hfinder/ec
