mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Wed Jun 16, 2021 10:47 pm
At idle, Nissan's spec for the fuel pressure test should be at 51psi. I have to assume, since you said it slowly dropped, that the engine was not running when you did this test. If it was running, a drop in pressure, even slowly, is not a good thing, especially when you were already measuring a pressure below where it should be. In either instance of how you did the test, without much else to go on, I could only guess that the fuel filter may be clogged. These integrated fuel level sensor/fuel pump/fuel filter assemblies buried inside the fuel tank are a pain in the wallet since there does not appear to be a separate part number for the filter that I could find.
