2006 O2 Sensor question.....
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
I wanted to know if a bad O2 sensor will cause your car to occasionally turn off. I have had this problem happen with the car turning while driving to today. I had the codes pulled but the only thing that came back was the O2 sensor on the right bank. If anyone has had a problem with this please let me know. Thanks in Advance!
atlM35
It's possible that the O2 is the issue if it's causing some sort of short.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
This has happened to me on my now, 08G35 Sport!! My check engine light comes on for a couple days then get the codes read and it's the 02 sensor just haven't got to it... My car has shut off on me about 3 or 4 times in the past 4 months... :gotme
svard75
Car: 06 M35x
I've had code P0430 come on a few times which never caused the car to turn off. What codes did you pull?
The Bodyguard
msvara wrote:I've had code P0430 come on a few times which never caused the car to turn off. What codes did you pull?
I can't remember codes right now... Light goes off when I go get them read sometimes... It went on again today so I'll go try and have the code read and I'll post it up! :bigthumb:
300freekzx
Thanks guys I will have it pulled today and get the exact code.
300freekzx
Ok I had the codes pulled again and it came back to be the TPS throttle position sensor. I cannot find any online do you know where you can get one from instead of the stealer ship.
atlM35
Regarding the TPS, I believe that it's all one unit with the throttle body and dbw unit.
They sell refurbished units at Advance Auto Parts for around $100 after you order online using the "P20" code and then you can go pick it up in person to avoid shipping.
The Bodyguard
300freekzx wrote:Ok I had the codes pulled again and it came back to be the TPS throttle position sensor. I cannot find any online do you know where you can get one from instead of the stealer ship.
Interesting thing... I had read o thread online somewhere about tps and one of its effects are the car shutting down!! My Check engine light on the G has stayed on this week but I didn't get a chance to get the code read... However, the car had stalled out once again (I'm usually able to quickly turn it back on) so now I think its time to research this some more!!
