i was thinking about splicing into the remote and rcas from the back of the deck and then running them separately to a separate amp and separate sub...my cousin wants to keep the 8 and then add another 10...not sure about splicing back before they reach the amp although it is a sound theory...im not too sure whether or not it matters how far from the source u splice but ive always assumed the closer the better...then ill just run the power wire through the firewall somewhere and then ground it to the torx bolt directly below where the stock 8 sits now...either way well be attempting it sometime here in the near future...this should be interesting although i dont think it will be more difficult then doing the system in my car...the 10 well be using is the 08 Kicker CVR and he has not chosen an amp yet...i just told him whatever he chooses make sure its a 400 RMS bc thats what the kicker calls forBig Nick wrote:cool i just bought an 06 special edition too ... well idk too much about the wiring in it but i too would love to keep my stock deck and cd changer in there.from having previous systems i would suggest that you just redo the wiring yourself. also if you are going to put in a new sub it may also be wise to get a new amp for the sub due to the fact that the amp pushes the sub, even if you have a 15 inch type R in there the amp will push out the same amount of wattage that its giving the 8 inch also i have never added an additional amp before but i believe all that you would need is a power block and another ground you can splice the remote wire into the exsiting one and i think (not 100% sure) you run the rca's from one amp to the other and then run the rca's from the new amp to the other sub ... but i guess thats only if your running 2 subs and 2 amps im not really sure
kbflip02 wrote:Ok so ive belonged to this forum for quite some time now but have never posted to anything pertaining to this particular model...in that sense here is my situation...oh and BTW I apologize in advance for any stupid questions...
my cousin has a 2006 Nissan Sentra 1.8S Special Edition with the rockford fostgate sound system(components,amp,8in sealed sub) and in dash 6 disc cd changer....he wants to keep the stock deck and components...i have several questions i need answers to:1)how would one go about removing the 8 inch box/sub and replacing with one 10in Kicker CVR in a single sealed box2)could i just splice the wires coming off the amp to the sub and wire them in there or what3)will the factory amp be able to run the 10in sub along with its components4)where/what would i run the remote wire and RCAs from the amp to the deck if there was an additional amp added assuming that the factory amp will not suffice5)would i still need a high low converter6)where can i get a wiring diagram of the stock stereo systemand finally #7...any reccomendations or write ups on this ever done???
any information you could provide would be greatly appreciated...thank you for your time and patience
