2006 Nissan Pathfinder: Cold start issue ?
Ceasar
Car: 97 Nissan Maxima SE
Wanting to find out if this is normal for the 06 Pathfinder from other owners perspective and/or a mechanical perspective.
When cranking (cold start) engine revs to around 2000 rpms then drops to around 1700 rpms then 30-40 seconds later drops on down to what I think would be normal.
Does this sound right to some of you with the same vehicle ? Or could there be a possible problem here?
thanks in advancec
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
So when it starts up it instantly goes to 2000 and then drops down to 1700 within a few seconds?
It is normal for the car to idle higher during however I dont think its normal for it to idle THAT high.. I would think that it would jump up to like 1500 and then setlle down to like 1200 or so...
bullrid
Car: 01 Pathfinder LE
on my 01, 2000 is not overreving on startup. it stays there for a while and eventually slows to about 1300 or so. the 2000 just gets the oil pressure up.
Pisspi
Car: 06 & 95 Pathfinder SE's
I'd have to say that's normal. I get that every morning when I go to work and idles bout 7 or 800 when hot.
trbochrg
Car: 2005 Pathfinder SE
I have a 2005 and it revs to about 1700-1800 then starts going down soon after....so i guess it is normal.
