2006 Nissan Murano CPS code P340
Forum for the unique Murano, and official home of Nissan Murano Club!
incah34
Car: 2017 Infiniti Q30 Sport Auto
Hi I have a code coming up of P340. Instrument panel show SLIP, VDS Off, Engine light and Driver side Headlamp activated. Deleting code engine stops. Anyone have any ideas.
incah34
Sorry Headlight Washer activated.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
You have a bad cam sensor on the back bank. The ECM is perfectly capable of running the engine using just the crank sensor, which it does after throwing the code. When you erase the code it tries to use the faulty cam sensor again and the engine quits. The slip and VDC lamps are derivative, they're because the ECM stops sending engine speed to the ABS and TCM when the engine is limping.
jethbon
Car: 2014 Nissan Pathfinder
If you need new sensors, avoid using aftermarket ones because they have a tendency to fail easily.
Return to “Murano Forum”
