WiseGuyMK wrote:I got a 2006 Nissan Maxima with factory Xenon HID headlights and Navigation. I recently got new fog light bulbs and i want to install them myself, can anyone tell me or send me pictures of how to change the bulbs? Also is the right bulb H3?
H3 is correct, you can do it from inside the engine compartment but it's a tight fit and a pain in the butt. The stealership will tell you they have to remove the bumper (which is the case for the headlights)
For the driver's side you need to remove the intake or the stock air filter. This will give you access to the bulb. For the passenger's side, remove the fluid reservoir (there's 2 10mm bolts holding it in place). After that you'll need to remove the fill tube for the windshield washer fluid. You can do this by twisting it counter clockwise. After that you should have access to the bulbs.
What bulbs did you buy?
