PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Fri Jan 04, 2013 12:08 am
It could be as easy as the nut coming loose off the stud on the handle finisher. You'll have to pop open the back of the tailgate to take a look.
Do you have a bedliner on your tailgate? If so, you'll have to remove it, as well as this small access panel on the back. Once that is off, you should be able to see EXACTLY what's going on.
