brotherjake70 »
https://forums.nicoclub.com/brotherjake70-u85113.html
Tue Jan 01, 2008 9:45 am
Good Day,
I have a 2006 Murano that is having problems starting. It seems when I turn the key, the engine is cranking hovwever it does not start. It just continues cranking. I have a full battery as I tired getting a boost and the same problem occurred. I thought it might be the key and tired all the keys and still I have no luck. I also tired putting the key in the ignition and trying it manually instead of using the key fob and still no luck. I have more than 3/4 of gas in the tank so I aknow it is not an issue of no gas.Any help would be most appreciated.
Regards,
