AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Mon Nov 30, 2009 3:57 pm
I'm glad you found the problem, but tires alone are unlikely to be the culprit... I stand by my assertion that the rear toe is out of alignment.
On a side note, 72 months (six years) warranty is utter insanity... I don't buy tires with a treadwear warranty (because I buy soft, sticky tires), but tires are pretty much useless after 2-4 years REGARDLESS of the tread (not thread) depth.
If they're cracking, check the manufacture date on the sidewall. If they're original, then they were likely made in 05, which means they're almost 5 years old - They're not "defective"... They're SHOT. They have 50K miles on them. You were due for new tires anyway.
The Yokohamas "felt" better because they're a "REAL" tire, and they weren't all dry-rotted. Look at the treadwear rating... I bet the Contis are a 400+ (hard compound) and the Yokos were under 280.
Keep in mind, the internal construction of a tire deteriorates as fast (if not faster) than the exterior... Especially in CT!
Promise us you won't drive on 5-year-old tires anymore.
