robo_geek »
https://forums.nicoclub.com/robo-geek-u75923.html
Sun Mar 15, 2009 6:51 pm
I have an 07 that does have a pretty healthy cold-start idle blip that's around 2000. Mine also whines, but that may be my CVT.
Cruise control on downhill: keep in mind that sometimes CC tends to drop the throttle off in a jerky way....if the automatic transmission torque converter is locked up, then it normally would unlock when decellerating downhill, to prevent jerkiness. I would try to mimic the CC action by driving and decelerating on a downhill grade to see if it's doing the same thing. Since these cars use an electronic cruise control (not vacuum), there is nothing that the CC can do that your foot cannot do on the pedal.
The two issues have some common elements: TPS, PPS.....but, OTOH if idle is normal after warm up, and no codes are stored, then this may be pretty much normal.
The servo sound is probably the electronic engine mounts doing their thing.
If it were my car I would check for stored trouble codes, inspect it very carefully for anything like a vacuum leak or damaged wire on the intake manifold.
If there is a problem, it would be with a sensor that's on the edge of being out-of range....the quickest way to do this would be with the Consult code scanner the dealer techs use.
The more intensive method would be to measure/test individual sensors to see if their input/output values are within spec.
The quick, expensive, and wrong approach would be to start swapping parts.
