amc49 wrote: ↑Wed Sep 27, 2017 10:11 pm
When you change studs you MUST ensure they are the correct ones, some in the catalogs will seem to fit but that last .010" of pilot OD will NOT go into the holes with the correct pressfit. Then they will always be loose and tend to break over and over............you need a total of around .005" interference fit to go in right and still last.
I say that after changing studs on 200 mph race cars with zero issues.
I agree with amc, you need to check that you are using correct studs & nuts, in both fitment & quality.
I would go straight to Infiniti to purchase these items.
One clue you gave is you stated you broke a stud while removing.
Only a few possibilities for that occurring, among them over torquing.
Was the stud stretched or the nut stripped from over torque?
Maybe the torque applied was OK, but the stud/nut was of inferior quality & could not accept the torque applied?
How is your torque wrench, what type is it, how old is it?
Torque wrenches are precision tools, maybe yours is not calibrated correctly!
A few other possibilities, (amc covered correct studs & nuts) so if it were my problem, I would start with correct OEM nuts & studs, followed by proper torquing with known good accurate T/wrench.
In any event, you have a serious issue at hand, so stay on top of it!
