So I pulled the stock Y out and tack welded the boss back on. I went ahead and grabbed a generic Y pipe off of Ebay to mess with (2 1/2" in, 3" out) and noticed just how close it is to the stock pipe. Got some 2 1/2" polished stainless pipe (Amazon RULES), some O2 standoff pipes, and flanges. Got most of the welding done today (use TIG for stainless) and I hope to finish, as long as it does not rain, tomorrow. The stock pipe necks down to 1 1/2" right after the cat and then in other places as well. Really weird design but I assume for noise abatement.
For anyone that wants to attempt this: the flanges off of the primary cats (on the exhaust manifolds) are weird, 2 3/8" opening with center to center bolt spacing of 4 5/8". I found some that will work but not in stainless on Amazon. Finally found some stainless at a custom exhaust shop.
Don't know how much louder it will be but I really don't care at this point as I am going for better flow and can deal with noise reduction later on (running Megan mid pipe back right now).
Should be fun and I'll keep you guys informed. I should be into it for about $350. Could have been done cheaper at an exhaust shop probably but I wanted stainless and secondary cat delete for when the car sees the track. Most shops will not touch anything with cats in California and besides, I like to do everything myself. I've already got replacement cats that will bolt in (similar to the M35) for street use (just need to weld the up pipe and O2 flanges on).
