2006 M45 Drainage tube issue
ISM
Car: Infiniti M45
The nature of the problem is water overflowing from the sunroof drainage tubes. I know the cause and possible solution to the problem, what I'm having an issue with is the best way to access the tube. I want to pry the A pillar apart but some photos I've seen don't show the actual tube. If anyone knows firsthand or can point the way to a instructional video, it be much appreciated.
Also I was planning on cutting the end of the drainage tube off to avoid this issue in the future. If you have thoughts on that I'm all ears.
Thanks in advance for any responses.
EdBwoy
There might be something helpful in here:
https://youtu.be/5gUGQx7Q1lw
After accessing the tube you'll be able to better diagnose what your issue with the tube is, but cutting it is not something I'd encourage
ISM
Car: Infiniti M45
I'll be working on this in the next day or so but thanks for the response and for all the informative videos you've uploaded. Definitely a resource I'll be referencing in the future.
