Craw »
https://forums.nicoclub.com/craw-u236657.html
Wed May 28, 2014 8:10 pm
Just had the engine replaced. Picked it up today and had to reset all of the electric gear - one-touch windows, seat position, etc. I expected that. Got home and started cleaning the car and realized that the key fob switch and dash release switch for the trunk are not working. Checked the trunk bypass switch in the glove box. There is very little discernible travel between positions on this switch. However, neither position allows the trunk to open, though I really can't tell if the switch is moving. Manual unlock with the key works. Is there a fuze associated with this problem? Am guessing that there is some connection to taking the engine out and disconnecting electrical power. The AirCon is also not cooling. It worked fine pre-engine replacement. Two electrical issues [guessing] like that sure sound like a fuze or a missed reconnection of some wire in putting the engine back in. Any suggestions other than take it back to the mechanic? I'm already going to take it back next week for a check up on the engine install, but I want to avoid extra trips for the time waste.
