What had happened was,....
Driving to work this morning on the highway feeling all good about my car with a 168k miles, as I just replaced the driver side wheel hub & bearing assembly all by myself, so it was a smooth ride doing about 70-75 with the intelligent cruise control working working again from the hub replacement. Then outta nowhere the trans slammed hard into neutral (WHAM!, car shakes), rpms shoot up and then the check engine light goes on. Rpms come back down and I am decelerating down the road in neutral even though I am in drive.
I hit the gas pedal and nothing, just the rpms went up , no engagement. I pull over on the shoulder, come to a stop, put the shifter in park and think for a minute on what to do next. I didn't want to turn the car off initially, so I put it back in drive, felt the trans engage and started to pull forward, unfortunately only first gear was available, it would not upshift. I then pulled back over and restarted the car. This time when I put it in drive and pulled away it drove like nothing was wrong, even though the check engine light remains on.
At lunch just now I went to Autozone and they pulled the P1774 code with no recommendations for fixes.
Hoping someone/anyone has some knowledge or interaction with this issue and some recommendations on how to fix.
Found these two articles, but not much use to me as a shady tree mechanic.
http://www.atraonline.com/gears/2007/20 ... _01_12.pdf
http://www.infinitig37.com/TSB/1ST25.pdf
