2006 M35x - Key Troubles
MrVitaliy
Guys can anyone tell me whats going on here.. I just bought a car on auction.. pressing on the buttons on the key does not open or lock doors, putting the key into the "key" hole, starts up a car...
Any help would be appreciated
szh
Car: 2018 Tesla Model 3.
MrVitaliy wrote:Guys can anyone tell me whats going on here.. I just bought a car on auction.. pressing on the buttons on the key does not open or lock doors, putting the key into the "key" hole, starts up a car...
Have you checked/replaced the battery inside the key fob? It is a coin cell ... type 2025, as I recall. Should be in the Owner's Manual ... PDF available at http://www.infiniti-techinfo.com if you do not have one!
Another possibility: you may have to get the key re-programmed at an Infiniti dealer ... but, since the car starts, this shouldn't be the issue.
Z
MrVitaliy
Thank you for your feedback szhosain. I will see if changing the battery helps.
szh
Good luck with it ... let us know what eventually cures the problem, please!
Z
MrVitaliy
it was a dead battery issue... thanks again szhosain.
szh
MrVitaliy wrote:it was a dead battery issue... thanks again szhosain.
Most Excellent™! Glad it turned out to be relatively simple fix.
Z
