chairmankaga »
https://forums.nicoclub.com/chairmankaga-u267200.html
Tue Mar 07, 2017 8:10 am
I replaced the original rack in my old CRV with a Cardone reman hardware from PartsGeek.com. My understanding was the original Honda racks, and quite possibly the Nissan racks too, as they seem to have the same problems, did not have a stainless sleeve inside the cylinder and the aluminum would wear prematurely, causing leaks at the O-rings as the tolerances increased. The remanufactured parts are actually superior to an original-style part as they have a stainless sleeve.
So I hear...
Mine is leaking a bit and groans when turning right when cold, so I have no doubt a replacement is soon on the agenda for me, too.
Check your tie rods though. My project Alfa had terrible steering slop when I bought it (manual rack) and simply replacing the tie rods and ends totally solved the problem. Replaced ball joints and bushings while I had the front end disassembled. It's the best handling car I've ever driven, and I haven't even done the rear DeDion or replaced shocks, yet.
Don't forget the alignment, afterward, if you DIY it.
