Larz »
https://forums.nicoclub.com/larz-u216291.html
Thu Jul 24, 2014 11:03 am
First, welcome to NICO. Second, I am NOT an automobile mechanic - just a member here.
Sometimes noises can be a bit tricky to pin down. Sound reflects off the ground and other surfaces and can seem to be coming from one area when in fact it is coming from another. I'm sure you've already considered that ... but have you had someone else drive whilst you sit on the passenger side - leaving all windows closed but yours so you can determine if the sound seems louder on that side Vs the volume you heard from the driver's side?
Another suggestion is to have the dealer take a look, but no doubt there will be a charge for that service so to avoid the charge, have the Infiniti dealer do the next oil change - that comes with a free inspection of things like steering linkage, brakes, tire pressure, fluids, belts, suspension, etc. At least then you will know that the noise is NOT caused by any of these things, narrowing the possible source of the noise.
You can also go to one of the auto parts shops and have them run a check for error codes - most do this free of charge.
Write down any codes that show and research the codes to determine if they shed any light on a cause for the noise.
Hope this helps.
