Hi all, my car is a 2006 M35x with just under 53,000 miles on it.
I seem to be having a common issue, where the rear part of my driver's seat has broken off the rails (first leaning towards the center console and now both sides are broken). Took this into the local dealership and they have quoted me $1,437.12 for a seat base assembly replacement (CDN$).
So, is this really the required fix and if so, how hard is it to do myself. I see online you can order this part for much less, but if it is difficult then it might not be worth saving the $500... 87450-EH00A,
http://www.infinitipartsusa.com/2006-In ... -90941.htm
They charged me $147 just to remove the seat to tell me the problem, not sure if that will be included or extra if I tell them to go ahead.
Also, they quoted me these items as "suggested"
drive belt replacement $215.95 (he said they were cracked, is this doable at home?)
emissions 179.95
brake flush 129.95
coolant flush 189.95
differential clean 249.95
transmission flush 199.95
power steering flush 139.95
Any replies are greatly appreciated. The car is unsafe to drive but I walk to/from work so it isn't a huge rush.
