tkeskic »
https://forums.nicoclub.com/tkeskic-u33292.html
Mon Jan 14, 2008 5:51 pm
You could try cleaning, and applying the silicon lube stuff the the door seals; for what it costs it may solve your problem; if nothing else, it will make the seals last longer.
The M35x I have is quieter than my MB ML330CDI for road noise (The MB is also 1 year newer with half the KM's); tires make a big difference also; I assume you have moved onto a new set as my 06 used up its tires at the end of last years, yours most be close to done or replaced already, that may be helpful to know what kind you have now
Also; check brake wear, you may be hearing that; but most people can tell the difference easy on those; tire noise seems to confuse some people for wind (more than average anyways)
I once had a car that I heard a metal grinding sound when applying the brakes, after two brake jobs (under warranty) and a bunch of suspension stuff being replaced, it turned out to be the tires, some defect of design that the bead near the rim on slowing would vibrate the tire/rim/suspension when the tire became a little older and sounded literally like metal; after 2 years of complaints, I replaced the tires due to wear, and found the issue went away; GM later paid me back 50% of the costs of the tires, and created a service advisory for it.
Stranger things happen, but hopefully this gets you looking at the issue a little different; service people cant spend too much time sometimes on these as they just dont have it to spare;, so working it yourself may be helpful; start with the silicon stuff for the door seals; parts departments all over sell it (dealers for sure, nit sure about the other kinds of parts stores).
also take one of the cars they have out for a drive on a road you drive and see if that is the same;
Good luck;tk
