Nissan hardly sells valve body component units for most of their transmissions and so do not disclose part numbers. However, it seems to me that the solenoid valve in question here has the part number 31941-90X01 available in many Chinese online stores. But, perhaps more reliably, it is also produced by Rostra with the part number 52-0538.
http://www.rostratransmission.com/
I think you should explore this. It just could be that you don't even need to replace the entire valve body.
With 180k on your odometer, the solenoid is probably clogged with dirt thus making shifting difficult. What symptoms do you experience?
