TXT »
https://forums.nicoclub.com/txt-u206721.html
Tue Jul 16, 2013 8:11 am
I had the same problem on my 1999 TL. Turns out one of the fans on my radiator(The fan used for the AC) did not work any more. I replaced the fan ($30.00 junkyard) and it fixed the problem permanently.
Not sure how your V6 engine is set up, but I assume its similar. Before you go and change your fan, I would first check a fuse that may be tied to any of those fans and make sure they work. That would be the easier and cheaper fix.
