2006 M35 Foglight Fuse Location
anish3232
Car: 2006 M35 Sport
2003 G35
I have spent the past 45 minutes looking at every fuse box in the car and can not find where the foglight fuse is located? I upgraded to HIDs a few weeks ago and now both of the fog lamps are dead. I later found out I should have changed the fuse to a larger Amp. Please Help.
Thanks
Q451990
The amperage of the fuse is determined by the wiring that it feeds. Putting a larger fuse in that spot makes it likely that you'll start melting wires. Better to add relays and feed them with the existing circuit if you're pulling more current.
Check out your factory service maual at www.nicoclub.com/FSM/
Looks like multiple fuses are involved.
Heath
anish3232
Car: 2006 M35 Sport
2003 G35
Thanks, I still can not figure out what fuses to look for. I looked at the Electrical Manual from the website and it still looks confusing. Would I be better off taking it to Infiniti?
Q451990
Why not check all of the fuses? You'll surely find it that way. Still doesn't solve your bigger problem unless you go back to standard fog lights though.
Heath
